4 members (Lightholder's Dad, Gdads51, SNOYL, 1 invisible), 150 guests, and 3 robots.
Topics128,258
Posts1,058,329
Members48,485
Has anyone successfully bolted the BW overdrive to the ol 4 speed SM420?
ODSS President
ODSS President
~ Cosmo
1949 Chevy Half Ton
I did and have used the search function which is not very useful for this forum, it could use an update. I know there has been discussion about overdrives for the sm420 but maybe one specifically has asked about the BW Overdrive being used with an SM420 which no one replied to.
I have been playing with BW overdrives for 50 years and have R10 and R11 back sections in my store room. I also have some SM420s. I have toyed with the idea, but I see no way of doing it without a lot of machine work. I think if I were to try to do it, I would start with a 4 speed with an open drive shaft and fabricate a nose section with with an input bearing on a shaft with a seal that would accept a companion flange. The nose section would have to include means to securely mount it to a cross member. I think making the OD unit into an divorced unit would be more doable than trying to attach the OD to a SM420. And then it would work behind any transmission with an open drive shaft.
There's a much simpler way to adapt a divorced OD than using the BW unit. Look at the Laycock De Normanville unit that was used on Jag, Austin-Healey, Triumph, MGB, and other Brit sports cars. It is identical to the Gear Vendors unit that's being sold for 5 or 6 times the price of a used Laycock. It would be very simple to either adapt the Laycock as a bolt-on extension to the SM 420, or fabricate an input flange to make it a divorced unit mounted on crossmembers. The Laycock is hydraulically-operated, and has its own onboard pump. A simple toggle switch is used to engage/disengage it.
Guys Thank you for the great info!
