Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (DirtTaxi, 1955 1 Series, 50Chevy3100, TooMany2count, Leo, 2 invisible), 564 guests, and 1 robot.
Topics126,781
Posts1,039,297
Members48,100
Most Online2,175
Jul 21st, 2025
#812872 01/03/2012 8:12 PM
Hi fellow bigbolters, I am new to the forums and have a question to ask! I Want to swap fenders on my GMC 4000 and need to know if any fender from 60-66 ( except LCF ) would work on my truck. It has the 7" wide fender flare to accomodate the bigger f070 axle. The truck is also a 24,000 gvw truck . Thanks Bluce in Frederick.
3B Offline
Hy bluce, you have a 1965 truck, according to my Canadian parts book the 7000 lb. front axle fenders are the same from 1963 - 66, pns 3856108 right, and 3856107 left. These are not the widest fenders available, the 9000, 11000, 12000lb. axle fenders are wider. The cowl fenders (school bus fenders) have a different p/n, so they probably won't fit either, hope that helps.
Bond Villain
Bond Villain
Bluce,
You might want to check with Mike B -- He might still have a set of fenders with that wide flare to fit your truck -- I was going to use them on my truck a few years ago but mine are the 3 inch flare and the wide flare would have looked odd on my set up.
With a 24,000 GVW, are you sure your truck is a 4000? My '65 4000 is rated at 19,500 on the VIN plate.
~ John
"We are not now that strength which in old days
Moved earth and heaven; that which we are, we are"
1948 International Farmall Super A
1949 Chevrolet 3804
1973 IH 1310 Dump
2014 Ford E-350 4x4 (Quigley)
John,
Didn't you take then for patch panels???
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1956 8400 Wrecker w/Holmes 525
1956 9200 Tractor w/Allison Automatic
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 Jeep CJ-5 Navy Jeep
1984 Jeep CJ7
Hughesville, MD
Bond Villain
Bond Villain
Mike -- I didn't use them because they had the wider flare. They're not here so I figure I gave 'em back to you ... ohwell
We ended up just using the original fenders ... Bondo and fibreglass is amazing stuff ... dance
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
where you at in fredrick ? im in charles town i may know where you can get a set is it chevy or gmc ??? are you going to leons on the 20th with us ? would hove to hang out some time
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
John,
I just went and double checked, I don't have them, so if you don't have them hopefully they went to a good home. Did you give them to Dale?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Hughesville, MD
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.527s Queries: 14 (0.028s) Memory: 0.6248 MB (Peak: 0.6999 MB) Data Comp: Zlib Server Time: 2025-09-22 21:14:36 UTC
Valid HTML 5 and Valid CSS
