7 members (Gdads51, Cletus1950, cmayna, 55shaker, 3800GUY, Gray_Ghost, FAST55),
145
0
Mod | | | Forums66 Topics128,109 Posts1,056,253 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi All,
I am going to convert my 1956 235 with the famed water pump adapter. It currently has the thinner 3/8" belt. I have done a lot of reading and figure that I can either stay with the 3/8" belt or go with the 5/8" belt. My plan is to add air conditioning so I would like to get a dual pulley harmonic balancer. My questions is should I go with 3/8" or 5/8" dual pulley harmonic balancer? Do most of the popular compressors (Sanden 508) use a standard size. Anyone have links to AC installs?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Chev did not make a dual 5/8" balancer, so yes to the 3/8". Most compressors use the 3/8" or 1/2" belt
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Patrick Dykes sells an A/C kit from Old Air Products. Both sites are a little vague about what type of crank pulley to use, other that a 3/8" belt is to be used. Buffalo Enterprises makes a dual-groove crank pulley-dampener for a 216-235-261 from a 292 pulley. I have one on my street rod with a 261. Steve at Buffalo does not have a website. You will need to call or write him: 25625 Dahl Road, Arlington, WA, 98223 (360) 652-7684 However, I do not have an A/C system on a 235-261 (yet), as I am between Stovebolt trucks. Hoyt | | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Looking at the OAP website it looks like their system is designed to work with a one pulley harmonic balancer. The alternator is run right off the compressor. So I believe a dual pulley is not needed? They did not mention needing one. Interesting, they also have a bracket for the chevy 250 engines to mount the compressor on the passanger side. I wonder if this could work with the 235 and if anyone has tried this. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I have the OAP system on my 55.1 3100. It does not require a 2-groove balancer. The AC compressor has a 2-groove pulley and it runs the alternator. I'm adding power steering, so I've installed a 2-groove balancer from Buffalo. I have a bracket set from Buffalo that I intend to install this winter.
regards, Leon | | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | I do not plan on using PS so I can probably get by with one pulley. Do you have any pictures of your install? Thanks! | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I could only find one pic of the compressor installation. regards, Leon | | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | It looks like you are using the 1/2" older style water pump. Very nice install, I assume that since the cab is a small volume, it must cool very effectively. I am quite happy with just rolling the windows down but my wife would drive with me more if I had AC:) | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I know this is an old post, but I just spoke with Steve at Buffalo about purchasing a two groove 292 harmonic balancer for my '52 216. Steve makes the two groove balancers to order and will make any combination of groove widths that you want. I decided on a 5/8" grove (closest to engine) for a the stock water pump and gen/alt setup. The outer groove will be 3/8" for the more common a/c compressor pulley size.
Steve charges $225 (plus shipping) whereas, Dale Mfg. charges $190 to rebuld your stock 216 balancer. No brainer to go two groove setup for versatility. I will be drilling and tapping the crank snout as well.
Edit: After more thought, I am thinking 3/8" for both pulleys. I think this will allow the use of a '53 216 water pump (3/8"), and common alternator pulley. So, can I just purchase a stock 292 vibration dampner and will it fit on the 216?
