2 members (Scott '48 2ton, dgrinnan), 141 guests, and 2 robots.
Topics128,163
Posts1,056,962
Members48,458
#812872 01/03/2012 8:12 PM
Hi fellow bigbolters, I am new to the forums and have a question to ask! I Want to swap fenders on my GMC 4000 and need to know if any fender from 60-66 ( except LCF ) would work on my truck. It has the 7" wide fender flare to accomodate the bigger f070 axle. The truck is also a 24,000 gvw truck . Thanks Bluce in Frederick.
3B Offline
Hy bluce, you have a 1965 truck, according to my Canadian parts book the 7000 lb. front axle fenders are the same from 1963 - 66, pns 3856108 right, and 3856107 left. These are not the widest fenders available, the 9000, 11000, 12000lb. axle fenders are wider. The cowl fenders (school bus fenders) have a different p/n, so they probably won't fit either, hope that helps.
24601
24601
Bluce,
You might want to check with Mike B -- He might still have a set of fenders with that wide flare to fit your truck -- I was going to use them on my truck a few years ago but mine are the 3 inch flare and the wide flare would have looked odd on my set up.
With a 24,000 GVW, are you sure your truck is a 4000? My '65 4000 is rated at 19,500 on the VIN plate.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
John,
Didn't you take then for patch panels???
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
24601
24601
Mike -- I didn't use them because they had the wider flare. They're not here so I figure I gave 'em back to you ... ohwell
We ended up just using the original fenders ... Bondo and fibreglass is amazing stuff ... dance
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
where you at in fredrick ? im in charles town i may know where you can get a set is it chevy or gmc ??? are you going to leons on the 20th with us ? would hove to hang out some time
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
John,
I just went and double checked, I don't have them, so if you don't have them hopefully they went to a good home. Did you give them to Dale?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
