| | | Forums66 Topics128,288 Posts1,058,579 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 22 New Guy | | New Guy Joined: Jan 2009 Posts: 22 | Fellow Stovebolters,
I am working on my 1954 3100 and am currently installing my new suspension components. The problem I am having is that I am unable to remove the shackle pins and bushings from the "fixed" ends of the old suspension. Has anyone else run into a similar problem? Any ideas? Thanks
John | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | The pins are threaded and usually will just unscrew easily. If yours are rusted in place you might try a pair of vice grips or channel-lock pliers to put a little more force on them. Maybe a few shots of Kroil or some other penetrating oil if they are really rusted in there.
After you get the pins out there is a DIY bushing puller article in the Tech Tips link above.
Good luck. | | |
