2 members (mo2cyl, Rusty Heaps),
59
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81325 08/10/2007 1:44 PM | Joined: Jun 2007 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 102 | I have been offered a free engine from a guy at work, engine spins freely all is ok, would need to be rebuilt, he's pretty sure its a 235, but my question is it came out of a 57 Chevy Sedan. Is this the same 235 they would put in the trucks? I don't see why it wouldn't be but I wanted to some other thoughts on it.
Birge :p | | |
#81326 08/10/2007 1:52 PM | Joined: Sep 2006 Posts: 13 Junior Member | | Junior Member Joined: Sep 2006 Posts: 13 | I think there were two different versions of the 235 but I think that was before 57. Take it the price is right, and good luck. | | |
#81327 08/10/2007 2:11 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | The only major difference was that the car engine ran a hydraulic cam and hydraulic lifters, while the truck engines ran solid lifters. If you want to find out a little more about the 57 engine this site has plenty of info: http://www.secondchancegarage.com/public/department35.cfm Hope this helps. Dave | | |
#81328 08/10/2007 2:30 PM | Joined: Jun 2007 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 102 | Hmm, is there advantage or disadvantage of hydraulic lifters as compared to Solid? | | |
#81329 08/10/2007 2:44 PM | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Birge - I've installed a 1957 235 out of car (it had hydraulic lifters and also had a Powerglide tranny attached when I bought it). My engine remanufacturer told me that there was no good source of reliable replacement hydraulic lifters, but that he did have a vendor in Canada who was good at refurbishing the existing lifters. The long and short of it is that the lifters were in suitable condition for refurbishment and the engine is now in the truck.
Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | |
#81330 08/10/2007 2:50 PM | Joined: Jun 2007 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 102 | Hmmmm Ok Thanks. I wonder why these are hard to come by, I will do a check on parts. But the price is right on this free engine. Not hard to rebuild. So I may as well try it, or see what condition its in and slap in the truck as is while I rebuild the 235 in the truck this winter. We'll see.
THanks | | |
#81331 08/10/2007 2:51 PM | Joined: Jul 2000 Posts: 579 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 579 | I'm not sure but I think the car engine has auto choke on the Rochester carb and the truck carbs are manual choke. | | |
#81332 08/10/2007 2:56 PM | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | That would be a good engine in a truck for a several reasons.It's full pressure oiling,it would have the higher HP number, especially if it came from a powerglide vehicle in 57 and it would likely have the higher compression 848 cylinder head. For your 52 you will need to drill 2 mounting holes in the front engine plate(it's not that hard) or replace the plate with an earlier version. And it's free ?!!! Take it even if you don't use it. Someone down the road will want it sooner or later.
Drew
#81333 08/10/2007 4:13 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Birge, I have seen conflicting information regarding comparison of 1957 235 engines in cars and trucks. Some references show the same horsepower, same head codes, and of course the same oil lubrication system. There is no question that the 1957 235 is more powerful than 1955 and earlier 235s (and a very large improvement in performance in comparison to a pre-54 216/235). Some references show the only significant mechanical difference is the lifters (I'll bet that truck 235s used automatic choke carburetors in trucks with automatic transmissions in 1957 - that carb should work OK in your truck). The front motor mount would need to be adapted (as described by DrewP). Also, the water pump would have to be adapted or replaced with a water pump that will work in an earlier truck (without the fan hitting the radiator). Other minor differences between car and truck 235s might be vacuum and mechanical advance values (no big deal), and the angles that tubes attach to the fuel pump and the vacuum advance. Different people see different advantages and disadvantages between hydraulic and mechanical lifters. Hydraulic lifters are available. Tim | | |
#81334 08/10/2007 4:24 PM | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Larry, you are correct. The engine did have an auto choke Rochester B installed. I have replaced it with a reman B from Discount Auto, but plan on installing my newly acquired NOS Carter FY 2100s soon.
#81335 08/10/2007 4:31 PM | Joined: Jun 2007 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 102 | Well guys Thanks, I think I will go ahead and pick this engine up, It will be easy enough to fix the front end of the engine with new or old parts. I will try to get it this weekend, also snap some pictures and maybe get the numbers so I can fully decode it. From what the old man gathers it has the powerglide attached to it. Not that I want it for my truck but hey I 'll bet someone wants it sompelace.
Thanks Guys As always everyone is a welath of knowledge.
Birge | | |
#81336 08/10/2007 8:58 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it is powerglide it has hydraulic lifters. If it is a manual trans it has solid lifters. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#81337 08/10/2007 9:14 PM | Joined: Jun 2007 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 102 | Well let me propose this question then, is it not a good idea to run hydraulic lifters on a 4 speed granny?
Birge | | |
#81338 08/10/2007 9:39 PM | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | but hey I 'll bet someone wants it sompelace. Don't bet on it. is it not a good idea to run hydraulic lifters on a 4 speed granny? I don't think granny will know the difference. Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | |
#81339 08/10/2007 9:57 PM | Joined: Jun 2007 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 102 | I wondered about that, I mean I always thought solid lifters were for high po or higher RPM applications, where as hydraulkic lifters were not I didn't know that the tranny cared either way.
But I am only a a novice Birge | | |
#81340 08/11/2007 12:06 PM | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | Birge,
I just did the swap you are describing. I've installed a 235 out of a '56 Bel Air into my '50 3100. The 235 originally had a Powerglide. Had a guy do the basic engine work for me and I dressed it out. The swap went much easier than I thought. Original carb had autochoke. I installed a manual carb to keep it original. My exhaust system bolted right up, no problems. All the linkage went on without a hitch. The front motor mount holes were there so no drilling. I was expecting some issues based on what I had read but easy change. And this is my first restoration.
Definitely take the 235. A bit pricy to rebuild but I had to look for a couple of months to find my 235.
It never costs more to ask and it never costs more to think big.
#81341 08/11/2007 12:49 PM | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | It's free so what you got to lose? I'd pick it up and bring it home. | | |
#81342 08/11/2007 1:12 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If it is powerglide it has hydraulic lifters. If it is a manual trans it has solid lifters. I think that all 1956-1962 passenger car 235 engines had hydraulic lifters (regardless of transmission). Someone with a 1956-1962 passenger car Shop Manual might be able to provide information (if anyone is interested). | | |
