4 members (Shaffer's1950, BC59, homer52, UtahYork), 98 guests, and 2 robots.
Topics128,038
Posts1,055,590
#813253 01/04/2012 8:17 PM
I have a 49 chevy P/U that I am putting new wiring harness in. I have everything in the cab wired up. Now I don't know how the wiring runs to the back of the truck. I know that the gas gauge wiring goes to the tank from under the door area. I have the rubber gromets in the rear installed. How does the wiring go from the firewall to the inside of the frame?
Bennie
I borrowed this photo from Jim Carter's web site, but it shows where the primary wiring goes through the firewall.
After it leaves the cab through the fire wall, one leg runs down under the cab inside the driver side frame rail... all the way to the driver side tail light. The other leg runs along the driver's side inner fender across the back side of the radiator to the passenger side inner fender.
Does that make sense?
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
The factory Assembly Manual should show most of what you need, including the clips to use.
- Lonnie
My '54 3104
yes thanks
