Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (51sub, Bill Hanlon, BC59, 2 invisible), 133 guests, and 2 robots.
Topics128,288
Posts1,058,571
Members48,492
I need the exhaust gasket that is between the exhaust manifold and the exhaust pipe. I tried NAPA, Autozone and a bunch of other places and have come up with nothing. I call Summit & Jegs and got zip from them also. It is 2 inch dia.
Any suggestion?
"The difference between genius and stupidity is that genius has its limits."
Albert Einstein
I made my own using the flange as a template. You should be able to get a sheet of exhaust manifold gasket material from any parts store. Even better, though, would be to get a some dead soft copper, which will seal better and last longer (no burnouts).
Bill Burmeister
The second item down on THIS PAGE should work for you.
Thanks, just ordered them!
Albert Einstein
Didn't the FLAPS offer you a Fel Pro #8985?
That's what NAPA and Oreilly show in their online catalog.
That's what I've always used.
regards,
Leon
