| | | Forums66 Topics128,288 Posts1,058,577 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 4 New Guy | | New Guy Joined: Dec 2011 Posts: 4 | I need the exhaust gasket that is between the exhaust manifold and the exhaust pipe. I tried NAPA, Autozone and a bunch of other places and have come up with nothing. I call Summit & Jegs and got zip from them also. It is 2 inch dia.
Any suggestion?
"The difference between genius and stupidity is that genius has its limits." Albert Einstein | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I made my own using the flange as a template. You should be able to get a sheet of exhaust manifold gasket material from any parts store. Even better, though, would be to get a some dead soft copper, which will seal better and last longer (no burnouts).
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | The second item down on THIS PAGE should work for you. | | | | | Joined: Dec 2011 Posts: 4 New Guy | | New Guy Joined: Dec 2011 Posts: 4 | Thanks, just ordered them!
"The difference between genius and stupidity is that genius has its limits." Albert Einstein | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Didn't the FLAPS offer you a Fel Pro #8985? That's what NAPA and Oreilly show in their online catalog. That's what I've always used.
regards, Leon | | |
