| | | Forums66 Topics128,010 Posts1,055,305 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81303 08/09/2007 3:57 AM | Joined: May 2005 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 65 | My free replacement frame came as a rolling chassis complete with another inline 6. I believe the frame is from a 1952 3100. The block casting number is 3835814 and it has the high position water pump, short sidecover and the two-bolt valve cover. I'm fairly sure this is a splash oil engine but don't know if it is a 216 or 235. Any thoughts?
1950 Chevrolet 1300
#81304 08/09/2007 12:58 PM | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | If it has a short side cover it's 235. The serial number from the pad behind the distributor will tell more. | | |
