8 members (Southerntruck, Gray_Ghost, Bill Hanlon, Otto Skorzeny, JW51, MRMEROTH11, Mike Burns, KEVINSKI),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,133 Posts1,056,396 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 47 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 47 | i'm trying to restore a speedo on a 50 1/2 ton chevy. i cannot remove the speedometer needle, so i can take the face plates off. am i correct that it should just pop off? any ideas for taking it off without breaking the spindle underneath? i've tried with my fingers and a couple of screwdrivers but it won't budge. thank you.
Che 1950 Chevy 3100
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Don't give up. I'm sure that a Stovebolter has had your same problem and solved it. While you're waiting, you might try a Stovebolt search with +speedometer +needle
The gauge cluster and speedo housing often got wet because of leaking windshield seals. Perhaps yours is rusted on. (?)
The only advice that I can give is to be careful when removing. I tried to remove the needle on a donor speedometer for my '54 and promptly broke the shaft. I put very little pressure and did not twist. But it still broke. The shaft was very brittle. Then I pried the needle off of the shaft of my "real" speedo. Gently pulled straight up. No problem. Whew!
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2010 Posts: 47 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 47 | thanks lonnie. i did another search and found a thread. it sounds like the needle has to be gently forced off the spindle. i'll try it and hope for the best.
Che 1950 Chevy 3100
| | | | | Joined: Sep 2010 Posts: 47 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 47 | this old speedometer had a lot of rust on the face place so i assume that speedo needle was rusted on too. after reading some posts here, i put some machine oil on the underside of the needle where it attaches to the shaft. i let it sit over night. then i moved the needle counterclockwise until it stopped. then with a twist to the left and an upward motion, the needle came right off without breaking the shaft.
Che 1950 Chevy 3100
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Congrats. < sigh of relief >
