2 members (BC59, G508), 77 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#812940 01/03/2012 11:25 PM
I looked and couldn't find the answer to my question, the metal fuel line from the pump to the carb, Does it have to be metal? mine is buggered up pretty bad but I looked at it and I don't see why I just can't use another length of rubber hose, same as from tank to pump, couldn't be used unless I'm missing something. The only thing I can see being a problem is heat from the engine, but I'm not sure how hot the engine gets where the fuel line runs.
If not, would Copper tube work to make a fuel line?
Thank you,
Josh
P.S. Where in the "side lot" forums are the Alaskans 'spose to post?!? smile
akguy34 #812956 01/04/2012 12:20 AM
Riding in the Passing Lane
It is done often but is not recomended due to fire hazards. Same with copper. You can buy steel tubing at any parts store in different lengths. They have both ends flared but generally you need to cut it to lenght & reflare one end. Specialty stores like LMC has them all made up.
1972 Chevy c10 Cheyenne Super
