1 members (CATMAN),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,935 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 3 New Guy | | New Guy Joined: Dec 2011 Posts: 3 | Hi fellow bigbolters, I am new to the forums and have a question to ask! I Want to swap fenders on my GMC 4000 and need to know if any fender from 60-66 ( except LCF ) would work on my truck. It has the 7" wide fender flare to accomodate the bigger f070 axle. The truck is also a 24,000 gvw truck . Thanks Bluce in Frederick. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bluce, you have a 1965 truck, according to my Canadian parts book the 7000 lb. front axle fenders are the same from 1963 - 66, pns 3856108 right, and 3856107 left. These are not the widest fenders available, the 9000, 11000, 12000lb. axle fenders are wider. The cowl fenders (school bus fenders) have a different p/n, so they probably won't fit either, hope that helps. | | | | | Joined: Nov 1995 Posts: 5,733 24601 | | 24601 Joined: Nov 1995 Posts: 5,733 | Bluce,
You might want to check with Mike B -- He might still have a set of fenders with that wide flare to fit your truck -- I was going to use them on my truck a few years ago but mine are the 3 inch flare and the wide flare would have looked odd on my set up.
With a 24,000 GVW, are you sure your truck is a 4000? My '65 4000 is rated at 19,500 on the VIN plate.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2004 Posts: 6,232 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,232 | John, Didn't you take then for patch panels??? Mike B  | | | | | Joined: Nov 1995 Posts: 5,733 24601 | | 24601 Joined: Nov 1995 Posts: 5,733 | Mike -- I didn't use them because they had the wider flare. They're not here so I figure I gave 'em back to you ...  We ended up just using the original fenders ... Bondo and fibreglass is amazing stuff ...
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | where you at in fredrick ? im in charles town i may know where you can get a set is it chevy or gmc ??? are you going to leons on the 20th with us ? would hove to hang out some time
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | | | | | | Joined: Mar 2004 Posts: 6,232 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,232 | John, I just went and double checked, I don't have them, so if you don't have them hopefully they went to a good home. Did you give them to Dale? Mike B  | | |
