7 members (JW51, TUTS 59, 3800GUY, Otto Skorzeny, cmayna, 52GMC35424JD, 1 invisible), 105 guests, and 5 robots.
Topics128,065
Posts1,055,863
Members48,428
#812562 01/02/2012 9:20 PM
Hello!
My '59 Apache 3600 is an original V8 truck. It's got a pretty tired 350 in it right now, and starting to plan for an engine rebuild/swap. Although the truck is basically stock, I'd like to build a nice strong street motor. Since it's going to cost me at least a few $1000 to put an engine together, so I'm thinking about a big block. The truck already has a limited slip Dana 60 with 3:54 gears, which work well with the 350. The stock SM420 will stand up to a big block, although I'd eventually plan to swap it out for a Muncie or Borg-Warner.
What issues, if any, would I have with fitting a big block into the Apache, i.e. oil pan clearance? Also, does the big block have the same bell housing pattern as a small block?
Anyone been there/done that? I want to know what I'm getting into before I start spending money.
Thanks...
Chris
buddy of mine put a 427 into a 55.2 with no issues .... and the V8 bellhouse patterns are all the same, with some differences in the size of the center hole for the trans front bearing retainer
The big block is a bit longer than the small block. You will probably want to install a side mount engine cradle.
