5 members (Wayne67vert, Gray_Ghost, tclederman, Ridgeback, 1 invisible), 56 guests, and 5 robots.
Topics128,021
Posts1,055,372
Members48,420
#812215 01/01/2012 6:49 PM
Hi all,
I have a '58 2 ton with a 4 speed that I assume is a SM-420 that is jumping out of 4th gear. Is there an easy fix for this? Or is it in need of a rebuild? Can they be rebuilt? Or would it be better to look for another tranny?
Big Bolt Forum Co-moderator
I was hoping to find a transmission manual on line at the old chevy manual project site, but could only find 3 and 5 speed along with automatics.
I am sure someone will chime in on the subject. But just wanted to relate a story about my 1952 Willys transmission. My brass syncro rings went out one time and I took the transmission out with the help of my manual. It wasn't hard to take it apart. Once I replaced the syncro rings and put the transmission back in and reinstalled it would pop out of gear. So I took it apart and the only thing I could find was there was a thrust washer on the back end of the cluster gear shaft that was a few thousands out. Got a new one and installed it, and that was the problem.
I would try to rebuild first if the gears are in good shape. If the gears are bad I am sure it would be cheaper to find another one. Good luck.
1948 Chevy 2-Ton
Super55 #812257 01/01/2012 9:22 PM
Flxible #812270 01/01/2012 10:08 PM
Bill,
Thanks for that link. I may have to use it sometime.
1948 Chevy 2-Ton
Super55 #812274 01/01/2012 10:34 PM
Before you tear into your transmission, check to make sure you have a pilot bearing and check your clutch housing for being off center. This will cause a transmission to jump out of high gear. Of course your transmission may have a lot of wear and need a rebuild, but I always like to check the easy things first.
crenwelge #812295 01/01/2012 11:37 PM
Thanks for the info guys, and Red58 thanks for the link I'm sure it will help.
harrydale #812585 01/02/2012 10:30 PM
Bond Villain
Bond Villain
Harry -- Google "SM-420 Rebuild" and you should get a lot of info (and pictures smile ) -- especially from the 4x4/rockcrawler sites. A few years ago, I rebuilt my 420 using info I got from several of these sites -- including a manual I downloaded from a Toyota landcruiser site (can't remember it now).
The rebuild is pretty easy and fun -- Heck, *I* did it. I got the kit from Stick Only in California, but the Novak kit looks great. The trick is to work slowly/methodically on a big, clean, well-lighted bench and keep all the parts in order (don't mix up gears or synchros -- or forget which is which wink )
Have fun!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
