| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | hi got a 37 with engine, i would like to test the engine to find out if it would even turn over but the starter is a floor stomp type newer starters you can touch the + and - with jumper cables but only one cable on this starter far as i can tell anyone have a diagram photo or ?? on where on the starter i need to jump it at
1937 1/2 ton
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Hook a set of jumper cables to the battery cables and push the stomper pedal. Easy! Jerry
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | lol prob with that no key, and far as i can tell no positive cable "missing i guess" but not going to use the 216 in it but just wanna be able to tell whoever i sell it to if it turns over or not
1937 1/2 ton
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Pull the spark plugs and turn the fan. If you really want to hear the starter motor connect the positive lead to the large lug on the starter switch, ground the housing and push on the button on the starter switch using a large screw driver pry bar.
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | No key needed. Just connect to the big terminal at the starter and push the linkage with a pry bar to engage the drive. Be careful not to short out the jumper cable clamp with the stomp linkage. Jerry
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | The engine will turn over whether you have a key or not. The key simply supplies power to the coil. Hook your battery up as suggested by Hotrod and Tiny, then press the stomp starter pedal. If the engine turns over, you might as well see if you can get it to start and run. I think it would sell better.
