0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81182 08/06/2007 5:27 PM | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | I have a 1959 Apache step side that I am replacing brakes on. It has taken a while and when I ordered my new wheel cylinders the part numbers does not match the catalogue number so I am not sure which one is left and which one belongs on the right? If I knew which way the Flex hose connection should face front or back this would tell left and right?? So if any of you could point me in the right direction I would appreciate it. Thanks | | |
#81183 08/06/2007 5:56 PM | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | The bleeder screw needs to be on top, never below the flex line fitting. If that doesn't solve the problem, just take a look at the length of the flex line, and install the cylinders so there's a maximum amount of movement without kinking the line in a sharp turn. Jerry
#81184 08/06/2007 6:20 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The hose connection points to the front.
Bill Burmeister | | |
