9 members (cmayna, BarryP, Rusty Heaps, DadsFirstPickup, Gray_Ghost, BC59, UtahYork, Peggy M, 1 invisible),
137
Mod | | | Forums66 Topics128,134 Posts1,056,738 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 27 New Guy | | New Guy Joined: Nov 2006 Posts: 27 | I have a failed vacuum advance on my 54 GMC. I got one from Carter (looks the same as one from Classic Trucks). I have found out Chevy and GMC have different vacuum advances and the brackets are different. The one from Carter has problems with tube fittings and looks a little cheap. It has most of the bracket also. I would also have to drill one hole for the bracket but it could work. I did get a NOS vacuum part only (no bracket) from Chevys of the 40's that has the correct tube fittings.
The problem is that the original vacuum is spot welded to the housing bracket and the NOS is screwed on. Were Chevys screwed on also? The vacuum part seems identical to my GMC. It seems the solution would be to hacksaw the vacuum part off the housing on my original one. I think there were 4 spot welds. Drilling seems harder as the spot welds seem larger than the drill holes would need to be for mounting purposes. Anyone run into this?
Also interestingly the NOS was sealed completely in wax packaging for storage. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Chev used the bolt on to bracket type up until about 1940. Most of the time you can change the fitting on the advance to get the correct fitting type for your tube. There is a spring under the fitting.
See the USA in your vintage Chevrolet! My Blog | | |
