13 members (Gray_Ghost, FAST55, 1955 1 Series, GusG, Bill Hanlon, sron48, Wally / Montana, Stovebolt48, JW51, GrandpasJimmy, tclederman, ‘37ChevyPU, 1 invisible),
71
Mod | | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Bought my total stock 1950, 3604 truck in September 2005 and over the next few year put about 8,000 miles of trouble free fair weather driving on it. The bad part was that she used a LOT of oil during those 8,000 miles. My compression was right up there and ya couldn’t see it smokin’ out the tail pipe, well, maybe at night in the headlights of the cars behind ya you could see a little haze, but there wasn’t any noticeable smoke in the day light and cleaning the plugs every 1,000 miles or so kept her running sweet as honey. See when I say she used a LOT of oil I mean 1 quart every hunert or hunert-n-fifty miles. Heck, my joy riding was costing me more for Rotella-T than it was for the petrol I was burning. The fact was that I was getting an oil change every five or six hundred miles, but I did do a real drain at about 1K just to flush out any of the black stuff, which made the fresh earl look like India ink after a couple hundred miles.
Back in the fall of 2009 I decided to put the new front bumper on, which I’d bought the first year that Bluebelle and I had meet. Well a new front bumper warranted nice fresh looking brackets so they came off. The gravel pan was already in a position for renewal residing between the two and while I was at it the grill could use a little sprucing up and on it went till the whole front clip was scattered about the garage. This offered easy access to the steering gear and at long last the Engine and transmission so now was the time to end the oil consumption that had been eating away at me for the past four years. Checking the bore revealed a slight ridge and about .006“-.008” cylinder wear from the 62,000 miles of faithful service she‘s performed over the past six decades. A month or so at the machine shop had the engine back home for assembly. Another year of procrastination went buy getting all the body parts, steering gear, and transmission back in shape. But it all came together this fall and in October I started giving her some road time. We just finished up with the Christmas bit and so far I’ve managed to put a little over 2,000 miles on the old gal. Changed the break-in oil at 500 miles, clear as a drop of dew and I’m now at about 1.500 miles on this charge of oil and it’s the same, clean as a whistle and that‘s with out any filter mind you!. And what I really like, the line on the dip-stick has hardly moved in all that time. So I’m forecasting the color of oil for 2012 to be, all clear.
Signed, One happy camper, Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Cool, my '38 is going in this week or next for bypass surgery. I have a wrist pin that's decided to retire.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What MPG are you getting after the rebuild?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Actually I've been getting a little worse mileage than I was before the rebuild Gus. I'm using the same carb (a W-1), the same distributor (on the ball), same plugs (AC R45), the same gas station. I have been a lot more aggressive in my driving though and have put a lot of miles on the interstate, toll ways and freeway and have been pushing it to keep up with the 55mph limits. I was running between 12 and 13 mpg before and now over the past 2k or 16-18 fill ups I'm averaging between 11 and 12. So it seems that it's dropped off by about a mile per gallon. However, no cost for oil! It may just be that she's still a little tight although I don't notice that when she starts hot or cold, it could be because she is .020" over bore, it could be the way I've been driving her and it could be a combination of all of these.
| | | | | Joined: Jul 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 54 | your milage should inprove as the engine starts to "wear in", their always a little tight after a rebuild. Keep drivin and change the oil, check the valves and try to avoid downshift that rev up the rpms while braking. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Here is an interesting thought. I wonder if the combustion of oil along with the gas contributes some energy as a fuel to the running of the engine. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You're thinkin' to hard Fred, I doubt seriously if that would have any bearing on it at all. In fact all the carbon that was created even appeared to have pock marked the valve seats from the valve job that was done when I first brough her home 8,000 miles ago. Luckly just touching them up with a little lapping compound and a stick cleaned them up without widening out the seats to much.
DG
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Denny, I wasn't commenting in relation to your apparent change in mileage. I was just wondering what affect burning oil would have in the actual amount of mechanical energy retrieved from the process.
Fred | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | gasoline = about 114,000btu/gallon .... waste oil = over 150,000btu/gallon .... maybe we should stop complaining about our worn out engines  Bill | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | yeah, but any extra energy produced is quite easily seen coming out the crankcase vents in the form of blowby. Not measured at the crankshaft. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just goes to show ya, don't use petrol to heat your house, right Willam!
Hey Fred, just pullin' you leg buddy, I know where you were headed. I tend to get off on those "what if" tangents all the time, as ya'll know by now...
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Denny, were you new pistons made by Egge. Mine were and the rings were much thinner, a more modern design. I was kind of surprised at the time when I bought them.
Fred
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep Egge supplied them. They might be the only ones around making new pistons for our stovebolts now. Hope the Egg doesn't decide to retire and shut down the business in the near future.
DG
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Ross makes "racing" pistons and Arias does or did also. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Don't know if they are making the stock replacement pistons for the older Stovebolts though Dave. But I do know that EGGE is.
DG
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | ross and venolia makes stock as well as higher compression as But they ain't cheap. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | TRW still makes forged pistons for them.
Bill Burmeister | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | federal mogul sealed power pistons are in my 1954 261,with hasting rings. sealed power pistons hasting ringsTim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
