| | | Forums66 Topics128,050 Posts1,055,759 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 15 New Guy | | New Guy Joined: Sep 2010 Posts: 15 | I was working on my parking lights today, and noticed when the parking lights are on my headlights are off. When the headlights are on the parking lights are off. My question is, shouldn't the headlights & parking lights be on @ the same time? Or, do I have a bad headlight switch? If the switch is bad, what is the procedure to remove it?
Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | why would you want the driving lights on when you're parked? or the parking lights on when you're driving  way back then, there was no such thing as "running" lights, and the lights were only on when you wanted them on, not ever ytime you started the truck like today .... if you want to have them on together, there's a tech tip here to easily accomplish that and welcome to the garage, check in the electrical forum and you should find a post about removing the light switch Bill | | | | | Joined: Sep 2010 Posts: 15 New Guy | | New Guy Joined: Sep 2010 Posts: 15 | So, are you saying the parking lights should not burn all the time? I had one of these trucks back in 85, and if I remember correctly, all the lights worked, when you pulled the headlight switch all the way on? When you wanted to run the parking lights only, you just pulled the switch out so far & it stopped. Is this correct or not? Or is the switch bad? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | 1st position, park lamps only...2nd position (all the way out), headlights only. If you want both the park lamps and the headlights on, in 2nd position, try this: Simple underdash wiring modification for park lamps & headlights on Cutting into the wiring harness for the headlights or park lamps, is not recommended or required with this simple modification.
