| | | Forums66 Topics128,154 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 64 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 64 | I know I have seen this somewhere but couldn't find it again. I am trying to remove the key cylinder from the ignition switch on my '50 3600.
I have the one with 2 holes and is a 2 position switch. I have tried sticking the end of a paper clip in both holes and one hole at a time and in the on and off positions. Can someone get me straightened out on this. I know its a simple thing but I just can't seem to get it.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My '38 has to be in the on position when the paper clip is inserted. Many have posted here that theirs had to be in the off position. You'll know when you're in the right spot when you feel a spring resistance to the paper clip.
| | | | | Joined: Apr 2008 Posts: 64 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 64 | Great, got it out, thanks for the help guys. Really appreciate the pics DADS50, very helpful.
Now anybody got any tips on getting a key cut to the original key number. I found the key number on some of the paper work in the glove box. If the door and glovebox locks haven't been changed from original then I would have the key for everything.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Get a B10 key blank and take it to a locksmith.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Right on Tiny, the locksmith will be able to read the code. I used to recode a lot of these when I was a parts man. The mechanics wouild bring them in to us and it was part of our job cus we stocked the keys, cylinders and tumblers. You might find this interesting Hap: http://ww2.justanswer.com/uploads/G...ylinder_removal_with_key_and_codeing.pdf DG
Denny G Sandwich, IL
| | | | | Joined: Apr 2008 Posts: 64 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 64 | Thanks guys. Denny, that is some great information, may come in handy some day. | | |
