| | | Forums66 Topics128,162 Posts1,057,059 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | Hi, Are the turn signals that mount to the side of the cowl extenions unique to that use, or are they top of fender units from something else? (earlier pickups?)
What I mean to ask is: Do I have to find those particular parts or can I use a turn signal as long as it has lenses that are amber front / red rear. Thanks Pete | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | put any kind of aftermarket signal lights anywhere you want, as long as the colors meet motor vehicle laws as you state
Bill | | | | | Joined: Jul 2004 Posts: 2,991 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,991 | What he said. Unless you're a real purist, most of the aftermarket units are similar enough that no one would know the difference. | | | | | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | Wow, Something easy to figure out?! Thanks guys. | | |
