1 members (RLB), 215 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#811372 12/29/2011 9:31 PM
V
V Offline
What will I notice going from a 15" wheel to a 16" wheel. Some say better gas mileage, less engine strain, etc. I have no idea.On a '57 3200 stock 6 lug.most likely a 390 rearend. Thanks for any and all input.
'57 3200
Leo Offline
Moderator
Moderator
Welcome, lower engine rpm, incorrect speedometer reading. This assumes your tires will be taller.
If you have an original engine you'll be able to travel a few mph faster at the same rpm. It may take more engine grunt to get loads going. I suppose it depends on the engine you have.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
If you are referring to stock wheels/tires, the 16" wheels/tires result in about a 3% increase in rolling diameter (1956 specifications).
There are almost infinite cobinations of wheels and tires available for your truck. You can likely find a 16 inch tire with the same diameter as the 15 inch tire. There will be very little difference.
A bigger concearn would be if the new 16 inch wheels have the correct backspacing. Modern 16 inch wheels are typically set inward, while the old truck rims from the 50s were generally centered. When the backspacing approaches 4 inches, the tires start to rub on the fron steering components.
15 inch tires are getting increasingly difficult to find, so 16 inch tires might be more available.
I currently have 31X10.5 tires on 15 inch 4wd rally rims from the mid 70s- mod 80s on my 59 1/2 ton longbed. I do not have the factory engine, transmission, or rear axle in my truck, so a comparrison will be apples and oranges. I do like the stance with the 31 inch tires. If I went any taller with the tires, I would likely have to find lower gears. I currently have 3.7:1 rear gears and a 27% OD. This combination gives around 2000rpm at 65mph.
