0 members (), 106 guests, and 3 robots.
Topics128,089
Posts1,056,440
Members48,443
#799726 11/21/2011 4:39 PM
who sales master cylinders for a 1.5 ton chevy. is it the same as a 1 ton model?
http://chevy.oldcarmanualproject.com/1929_54chevyparts/04/293.HTM
The Master Parts Book shows that some of the 1952 1-tons and 1.5 ton trucks used the same master-cylinder.
What type of 1.5 ton truck do you have?
Rockauto.com has a few 1 1/4" bore master cylinders for 1952 1-ton trucks. Maybe someone with a parts book or an interchange book will post information?
Big Bolt Forum Co-moderator
I think a lot of vendors must sell them. I went to Jim Carter and got this:
http://www.oldchevytrucks.com/cart/index.asp?cat2=10187&path=1947+-+Early+1955+Truck+Parts%2FMechanical%2FBrakes%2FMaster+Cylinders+and+Repair+Kits
Don't know why that link isn't showing up as a click on link. Try copy paste. But go to Jim Carter online if the link doesn't work. They have a master cylinder for $99.
1948 Chevy 2-Ton
Super55,
Jim Carter's MC's on that page are for the 1/2 ton trucks with the 1-1/8" bore. The 1-1/2 ton trucks use the 1-1/4" bore MC's.
If you MC is not pitted you can rebuild it with a kit from NAPA...if it is pitted you can send it to Serria Specility Automotive and have Joe put a brass sleeve in it. New MC's are hard to find for the big trucks.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Originally Posted by Mike B
Super55,
Mike B smile
If you scroll down to part Item # ME166 it is for 1 1/2 ton.
1948 Chevy 2-Ton
Super55,
I stand corrected...I missed that one, that would be the 1-1/4" MC.
Thanks for keeping me straight!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
thanks for the help. its a 1.5 ton without power brakes. Its my first chevy, I know the early fords use the same master cylinder from 1-2 ton trucks. I removed the master cylinder and found it is one from a 1/2 ton so rebuilding it is out the question and the only ones I found so far only go up to a 1 ton but I did not check jim carters, thanks for the help
Matthew,
Are you sure you don't have a Hydrovac (power brake booster) mounted on the frame? I thought they were standard equipment on the Medium and Heavy Duty trucks...am I wrong?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Alretta Truck Parts, is by far the best place to seek brake parts for these big Stovebolt Trucks. Quite a few members from this site have used them. Contact Geoff @ (508)788-9409.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
yep positive. I suppose it might have had one when it was new, but it does not now. I personally am a gmc man but some years back I was given a 51 ford f6 two ton and am much more versed in the ford medium duty trucks than the gm versions. On the fords power brakes were an option on the 1.5 tons, chevys I really am not sure.
Thanks for the help guys. being my first gm medium duty I am still learning all the good parts places.
Napa can get the larger master cylinder, thats where I got mine.
