1 members (Hotrod Lincoln), 125 guests, and 2 robots.
Topics128,080
Posts1,055,952
Members48,430
#810875 12/28/2011 4:42 AM
can someone tell me what was the last year for the 250 &292 6 cyl used?
johnhull #810879 12/28/2011 4:50 AM
I believe 1984 for the 250 in cars or trucks. I don't know how long for the Marine version. The 292 about 1988. If this is off, someone will correct me.
best wishes
Les
Roadmarks #810919 12/28/2011 6:23 AM
thanks,for the quick response.i have another quistion for someone.did the late model use hei ign.thanks again.
johnhull #810931 12/28/2011 7:38 AM
J M Offline
I have a 250 that I believe is a late 70's and it has a hei ignition.
Jim
J M #810939 12/28/2011 8:05 AM
Jim
1975 HEI became standard.
BC
1960 C60 pasture art
BC59 #811007 12/28/2011 3:28 PM
thanks guys,looks like i am off to pick&pull today.
johnhull #811398 12/29/2011 11:15 PM
@johnhull, GM lists 1975 as the start, but as with many things, I think they "rounded it off" a little. I'd say last third of 1974 on. Anything that used the 230/250/292 seems to use that date. For the first year, there was a remote coil. Then GM went to coil in cap for the sixes, just like the V-8s. If you don't have any luck with the U-PULL-IT, I'd try Skip white in TN. http://www.skipwhiteperformance.com/detail.aspx?Item=6522-R
Their distributors are made in Australia by Holden, not china like the snobs say. I have 2, one in my '69 and one in my '71 and both work perfectly, plus I've installed 3 others.
Another side note; you MUST run a new 12gauge switched wire from the ignition switch or the bulkhead plug depending on the truck.
DO NOT use the old yellow/pink/purple coil wire! It is to small and has built-in resistance. You MAY also have to upgrade your alternator to the internal style like the 10si when you change distributor.
The distributor plug, if you don't get it from the pick&pull can be had under the Accel #170072 which includes the tach lead.
I hope this all helps!
Best wishes,
Les
Roadmarks #811436 12/30/2011 1:50 AM
well it was abadday at pick&pull,noihing but v8s,but i a,m not in any hurry.thanks for the info.
johnhull #811483 12/30/2011 4:09 AM
If you find the distributor on a Chevy truck, get the wire from the firewall plug too and be sure to note how/where its run. I'll bet the cars have the same wire! Look at Chevy Camaro, and Nova, but don't forget Olds, Buick, and GMC who also used the 250 and bigger trucks that might have the 292. Chevy and GMC VANS, too! If you get to a boat junkyard, there's a marine version of the 250 that has HEI and some NEAT Mercrusier side covers and Valve covers!
Good luck!
Les
Les
