1 members (UtahYork),
88
Mod | | | Forums66 Topics128,142 Posts1,056,491 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 150 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 150 | I want to put bearclaw latches on my 49 3100. Would like to keep the outside handles. I've seen a variety of latch sizes and quite a spread of prices. Whose would you recommend? Cutting and welding is not a problem so I've not considered the bolt-in type.
| | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | www.bowtiebits.com has them in stock. Normbc9 | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I know welding doesn't phase you but I quite like these bear clawsI'll stick with originals just now but would consider these if the need arises. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i looked around trying to save some money but ended up going with the altman easy latch kit....saw for the first time in 2010 and was impressed.thought about it for a yr. and bought at the NSRA Nats this yr....i wanted to use my original handles and could not figure out how to do that...was dragging my feet because you cant lock the doors from the inside and i only have the one door lock on the passenger side..contacted the mfg. and they said yes i could install a lock on the drivers door as well...i'll just take them to a locksmith and have them keyed alike......also now if you're a Hamb alliance member,they're a vendor......dave
1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I want to put bearclaw latches on my 49 3100. Would like to keep the outside handles. I've seen a variety of latch sizes and quite a spread of prices. Whose would you recommend? Cutting and welding is not a problem so I've not considered the bolt-in type. I used a set of large bear claws that I got off Amazon for $35. I decided to shave my door handles but to use the stock handles you can use a set of these to simplify matters. I came across a set of marine style locks that would allowyou to lock both doors. I'd looked long and hard at the Altman setup as well but figured that I could go this route for less than $100.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | ...the altman easy latch kit... I've also researched latch kits and methods and that's what I'll be using (haven't bought any yet). The ones I've seen installed looked excellent, very professional, and worked perfectly smooth. Grigg | | | | | Joined: Jun 2011 Posts: 150 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 150 | Ordered latches from Windsor Fabrication. The guy doing my body work recommended these because he has used their stuff in the past. We will be re-using the original pull down handles on the outside. Windsor's phone number is 269-964-2128 they are in Battle Creek, MI. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I looked at the Windsor Fabrication site, is this what you're looking at? http://www.hotrodssuperstore.com/19chevtrucbr.htmlWonder how they compare to the Altman kit if it's even an apples to apples thing? I was impressed with how easy to install and professional looking the Altman kit is, made for the truck, no fabrication necessary like some other latch options. Grigg | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Hostess has pretty goood bear claws. | | | | | Joined: Jun 2011 Posts: 150 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 150 | That's the kit. I haven't got it yet but the guy doing my body work has used it on several builds and says it's the one he prefers. | | |
