9 members (wilbur53, Otto Skorzeny, Greg_H, 68ironhead, WICruiser, Gdads51, Shade Baby, rinemb, 1 invisible),
243
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,075 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | I did some searching but came up with nothing.
Can some one tell me the ride height at the front and rear bumpers, or where ever you should measure, for a 1958 1/2 ton longbed?
Much appreciated bolters!
58' 3200 235 3-speed/OD
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | there should be a slight rake empty to allow for loading, depends on the original GVW springs - ballpark on mine: the bottom of the front bumper is 15" [front springs may be sagged a bit] .... rear might have various bumpers or none, so with the fleet bed, it's ~28" to the bottom of the tailgate, should be the same to the gate of a stepside .... or you could check the resto-pak  Bill | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | That's perfect! Thanks Squeeze!
