1 members (RLB), 215 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#810743 12/27/2011 10:48 PM
I did some searching but came up with nothing.
Can some one tell me the ride height at the front and rear bumpers, or where ever you should measure, for a 1958 1/2 ton longbed?
Much appreciated bolters!
58' 3200 235 3-speed/OD
there should be a slight rake empty to allow for loading, depends on the original GVW springs - ballpark on mine: the bottom of the front bumper is 15" [front springs may be sagged a bit] .... rear might have various bumpers or none, so with the fleet bed, it's ~28" to the bottom of the tailgate, should be the same to the gate of a stepside .... or you could check the resto-pak wink
That's perfect! Thanks Squeeze!
