5 members (55shaker, Hambone, dunfire, Rexville48, WICruiser), 114 guests, and 5 robots.
Topics128,014
Posts1,055,328
Members48,419
#810488 12/27/2011 12:29 AM
I just put in a new fuel tank, and I have a new fuel line for it. From what the assembly manual says, the fuel suction comes from the top of the tank. But I cant find any sending unit with a suction line going down in the tank like what the assembly manual shows. I could tap off the drain plug, but I cant find a fitting that converts 5/16 normal threads to NPT. Truck is a 53 half ton, with the tank behind the seat.
[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
davidn #810492 12/27/2011 12:47 AM
The top suction feed line was introduced in '54. The aftermarket sending units I have seen are of this type. Check with the usual truck specialty suppliers.
Also, depending on the source of your new tank, the drain plug may be metric threaded, not NPT. I'd advise converting to top feed.
Cletis #810508 12/27/2011 1:39 AM
Please provide a link. I ordered a sending unit from american truck parts. It is not top feed. Every sending unit that I've looked at is not top feed. I'd rather just tap into the bottom, but cannot find the right reducer. It is 5/16 standard thread.
davidn #810510 12/27/2011 1:45 AM
Found one. Thanks. I had to search for 1954 instead of 53
