4 members (Shardean, Tstan7, 2 invisible),
94
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 11 New Guy | | New Guy Joined: Sep 2007 Posts: 11 | im going to try and put the windield back in my 66 chev. truck. what is the best way to do this? thanks carl
fdhhfdhtyy
| | | | | Joined: Sep 2007 Posts: 11 New Guy | | New Guy Joined: Sep 2007 Posts: 11 | i just seen how to do it in the tech tips!!!
fdhhfdhtyy
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | 3 sets of hands, will make the job much easier, than trying to do it with two sets. Misting the rubber grommet & windshield with a 50/50 mix of dishwashing liquid & water will help, as well. The pull-cord method works great if the rubber grommet is good quality & the rope is woven nylon or polyester. I have found the 1/4" tight-weave rope is the best. | | | | | Joined: Sep 2007 Posts: 11 New Guy | | New Guy Joined: Sep 2007 Posts: 11 | ok thanks: i have the new rubber grommet from LMC i was going to try it with a 1/4 rope with soap/water. thanks again carl
fdhhfdhtyy
| | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | I just replaced my windshield rubber in my 58. I also got mine from LMC. I took the back window out and cleaned and primed everything but when I started to go back with the glass it just did not want to go in. I finally called a guy who has done glass work for me on oyher cars.When he installed that glass with the seal he had to hit that glass so hard I thought it would break. He did a nice job for $100.00 and it has not leaked at all. Good luck with your install I hope it all goes in real easy. | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | i had a new windshield put in my 66 by one of the many windshield replacement outfits in waco they drove out to my shop and put it in in less than an hour. i was amazed at the pounding that guy gave the glass but he put it in no sweat. if i'd have done it i'd have broke it.
1963 c10 | | |
