7 members (Chip O, 1955 1 Series, Gray_Ghost, JoergK., Peggy M, oldieoldie, 1 invisible), 177 guests, and 3 robots.
Topics128,191
Posts1,057,348
Members48,469
I found a '50 GMC 1/2-ton that I'm probably going to get in the very near future. One option I'm thinking about is taking a Jaguar and gutting the front and rear suspensions from it, and putting them on the truck! I know it's been done before by someone here. I've got a line on a running '88 Sovereign sedan for dead cheap - less than a grand! I know both the front and rear suspensions off the Jag unbolt from the car as a unit each. This, of course, would yield four-wheel disc brakes, independent rear suspension, and a very highway-friendly gearing with limited-slip differential.
Is there anyone here with first-hand experience with this swap, especially in a '47.2 - 55.1 truck???
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
Sir Searchalot
Sir Searchalot
I have not done it but have studied it and have some good info/emails from Dyna Ares, a British Bolter here, and others. Some good advice, pics and drawings. Send me a PM with email address and I will forward to you.
Sir Searchalot
Sir Searchalot
The fellow is on here as dyn_ares
Drew
WOW! The Jag engine in my potential donor car is toast, but that suspension install looks amazing! Very impressive, indeed.
I'm too far into my build to use a Jag set-up but would seriously consider doing it in another future project.
At least the rear end anyway.
I've always liked the Jag IRS.(it looks great with a little work and it rides/handles really well.)
There's a good selection of diff ratios too.
Plus they're common here in Blighty.
If a truck rides half as good as a Jag,I would be more than happy!
More pix on Flickr.
The 1950 GMCs I was considering are quite a bit rougher than I was hoping, upon closer inspection. The 5-window cab has a horribly pitted and rusty ROOF all the way to the bottom of the windows! The doghouse and doors are good (this is the one-ton), and this one has a title. The frame is useless, due to a lifetime of hauling manure and letting it settle on the frame rails. The 1/2-ton has a good door and hood, and a decent 3-window cab. Decent bedsides. Both have 228 engines and four-speeds.
So, with that, I continue to look around for the right project.
I just had to bookmark that page, thanks!
Sir Searchalot
Sir Searchalot
there is a UTUBE or two on Jag-TF trucks.
Found one a bit ago, pretty decent description of the build.
