Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Stewart2, red450IH, 50Chevy3100, Stovebolt48, Steveoreno, 1 invisible), 168 guests, and 3 robots.
Topics128,288
Posts1,058,581
Members48,492
I need the metal oil line that goes from the pump to the block on a '55 235 straight 6. I removed my oil pan to check out the loss in oil pressure and found that line all mangled. Apparently someone tried to remove it without dropping the pump.
Any help would be greatly appreciated!!
Thank you!
Andy
I believe a new line can be formed from a 1/2" steel fuel line and a tubing bender. The end fittings are regular compression sleeve type fittings, available at any hardware store, and/or most good auto parts places.
Andy,
I might be way off base on this, but can't you buy a hunk of copper tubing, two ferrules and reuse the old nuts to make a new line? I have either done this, or seen it done...don't remember which!
Stuart
I'll try to make a new line. I just thought it would be easier if someone had one lying around.
The old line is actually 7/16" steel and I can't find steel or copper in 7/16" anywhere. I'm going to use a 3/8" brake line with flared ends and some new adapters into the block and pump. Anybody see a problem with using 1/16" smaller line? The hole going through the block will still be the same size anyways...
I believe I'd adapt a 1/2" line instead of a 3/8", just for the extra volume capacity. There should be inverted flare to pipe thread fittings available to make the transition from the pump and the block to the tubing fittings.
