| | | Forums66 Topics128,132 Posts1,056,376 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80957 08/03/2007 10:35 PM | Joined: Aug 2006 Posts: 29 New Guy | | New Guy Joined: Aug 2006 Posts: 29 | I wanted to replace the axel bearings on my 63 c10 and when I pulled the bearings out there is a bearing retainer (that is what the book calls it) behind the bearing. I was able to buy a large washer that is close to the same as the retainer, but is not as thick as the original. My question is will this washer work OK, or do I need the exact thickness as well as ID & OD? And if I do need the exact retainer, where can I get a pair, no one I went to today had them available, or even knew about them.
Thanks, Rick | | |
#80958 08/03/2007 10:44 PM | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | The retainer is a precision-size, press fit piece, and a new one comes packaged with the replacement wheel bearing. We usually take a wide chisel and a BIG hammer, and with the axle sitting firmly on an anvll, make a couple of deep scores in the retainer. That loosens it so it's easier to press the bearing off the shaft. Press the new bearing and retainer on together. Be sure to change the seal in the bolt-on axle retainer if it has one. Jerry
#80959 08/03/2007 11:17 PM | Joined: Aug 2006 Posts: 29 New Guy | | New Guy Joined: Aug 2006 Posts: 29 | I am picking up my new bearings in the morning (sat) and will see if the retainer comes with them. Also, my bearings are pressed into the axel tube, not on the axel it self. Does this change your answer at all?
Thanks, Rick | | |
#80960 08/03/2007 11:39 PM | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | Yes, absolutely! That one uses a seal outboard of the bearing, in the housing, and I've never heard of a "retainer" being used on that setup. The outer shell of the bearing just drives into the housing. It takes a slide hammer puller to remove the old bearing. There are some special offset bearings available that put the contact area between the bearing and the axle in a different location, but that's only necessary if the axle has a worn area where the bearing rollers run. Jerry
#80961 08/04/2007 12:45 AM | Joined: Aug 2006 Posts: 29 New Guy | | New Guy Joined: Aug 2006 Posts: 29 | Thanks Jerry,
My shop manual is calling the washer/shime a "retainer", that's why I used that term. It says, "discard bearing retainer and us a new one upon reassembley". I just don't know if the thickness of this retainer is critical or not.
Rick | | |
#80962 08/04/2007 1:25 AM | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | Hmmmmm- - - -is this part a thin sheet metal type washer that fits on the inboard side of the bearing? If so, it's probably there to reduce flooding the bearing with rear end grease when the car is in a turn. A little grease will find its way past the washer and keep the bearing lubed, but most of it will get deflected back toward the differential. If the washers aren't damaged, reusing them won't be a problem. The axle shaft shouldn't contact them at all, they're just a sort of deflector to keep from overloading the axle seal with grease during a turn. I believe I've seen them, now that you mention it, but seldom. Jerry
#80963 08/04/2007 2:39 AM | Joined: Aug 2006 Posts: 29 New Guy | | New Guy Joined: Aug 2006 Posts: 29 | It sounds like we are on the same page now! That is just what my Dad said he thought they were, but the book just doesn't discribe there function very well. A bearing retainer to me seems like something to keep the bearing in a certain place, that's why I wondered if the thickness was important.
Thanks, Rick | | |
