0 members (),
88
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | My 1951 Chevy suburban came with a 1956 hydraulic 235 passenger car engine coupled to the original bellhousing.It didn't have a clutch inspection cover on it and the two different ones I have will not work.Can anyone tell me what I should be looking for ?Will a original car inspection cover bolt up with the truck bellhousing ? I'm lost guys.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Should use the ones I underlined.
Flywheel Under pan:
1937-48 Passenger 839335 1949-62 Passenger 3688221
1937-53 PU 838438 1954-55 1st PU 3702830 1954-62 PU (w/ 3731645 clutch) 3725088
Front Extension:
1937-39 Passenger 838484 1940-48 Passenger 839131 1949-54 Passenger 3688218 1955-62 Passenger 3836317
1937-39 PU 838483 1940-62 PU 839180
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I will pull the one off of my 1954 261 and see if it will match up.
Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Thanks for the information and thanks to Mike Taylor at oltrucks for having the parts.
