| | | Forums66 Topics128,090 Posts1,056,443 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | been awhile since i installed the tank, not getting gas out of it. my sending unit has 2 pipes coming out of it. One should be the pickup tube, the other the vent. I suck on the fuel line at the filter, but no gas. maybe i'm not sucking it up high enough? trucks starts and runs on starting fluid but no gas pumping through the line. All fittings clamps tight, no kinks. gasket in filter bowl. WTH? Build and maintenance manual only shows one tube. So close yet so far! And pleeeeeze don't ask me if there's gas in the tank lolol. | | | | | Joined: Nov 2011 Posts: 15 New Guy | | New Guy Joined: Nov 2011 Posts: 15 | Ok try checking the the acctual Pump. Is it an electric pump or the stock pump. You know that if it runs with everything else then you need to check the pump.
| | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | pressurized the gas filler, everythings fine, just needed priming i guess | | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Disconnect at the pump inlet and add a rubber hose into a gallon of gas,if it primes you have a problem between the pump and tank.If it doesn't prime then I would suspect the fuel pump rod is missing (if required ) or the pump is bad
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
