2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#808634 12/20/2011 6:11 AM
working on my `59 cab and it has the normal rot above the windshield (inside and out)
[IMG]http://i236.photobucket.com/albums/...oject/photobucket-2974-1324355955759.jpg[/IMG]
[IMG]http://i236.photobucket.com/albums/...oject/photobucket-4120-1324356037338.jpg[/IMG]
Does anyone make repair panels for these two areas without doing the whole roof & inner?
1959 Shortbed stepside 1/2 ton project
[Linked Image from i236.photobucket.com]
olddaze #808635 12/20/2011 6:20 AM
nope, you're faced with fabbing it all yourself or finding a donor cab to chop parts from
olddaze #808877 12/21/2011 2:05 AM
the first thing you need to do is get these areas blasted so you can really see where you stand. I did the 4 corners on my 51 made the pieces and tig welded them in, but you have to be back to good metal which is usually twice as far as you think. Make some templates before you cut anything out!
1951 chevy 3100 short bed frame off resto.
