6 members (tclederman, gswbbc, TIM ZINDLER, HandyAndy, Stovebolt48, rfs56trk), 94 guests, and 2 robots.
Topics128,040
Posts1,055,478
Members48,424
#808393 12/19/2011 8:14 PM
1 Offline
I got a 64 3/4ton chevy 4spd drive-train 4x4 with a 350. I don't have a tachometer so i was wondering what speeds are usually a good time to shift on flat ground? I understand i can figure it out by using sites to figure it out but i'm unsure of what the gears in the transmission, 1st is something like 7:1. does anyone know what the axle ratio is?
Assuming that the trans and axles are the oem parts, your ratios are as follows;
Transmission
1rs- 7.05:1
2nd- 3.58:1
3rd- 1.71:1
4th- 1:1
Reverse- 6.78:1
The axle ratios should be 4.55:1 front, 4.56:1 rear.
Bill Burmeister
1 Offline
Thanks!
Run it hard once then deduct 100 rpm for fun driving,500 for normal. You can feel it when it poops out running hard.(shift quicker) Other wise just shift it soft. You arn't racing any one are you?
