5 members (Johnny N, tesa, Chris's 46 / 515, Gray_Ghost, Youngin' Tut 59), 76 guests, and 2 robots.
Topics128,076
Posts1,055,924
Members48,430
#807792 12/17/2011 11:51 PM
Here is what I'm looking at to do some trading on...
1) 1950 GMC 1-ton w/flatbed. 5-window cab, titled, sheetmetal is good, frame is eaten up from the PO hauling manure on it for over 40 years! Roller. Everything is there.
2) 1950 GMC 1/2-ton with bed, 3-window cab. Homemade divot on RR fender to accommodate a spare tire. No papers, runs with help, roller. Cab is so-so, bed sides are good, front clip is good.
I've been looking for an AD truck for awhile now, and these look pretty good. I plan on using the 5-window cab from the one-ton and building the half-ton int a nice driver.
Questions: What engine would both trucks likely have? Aren't all of the AD GMCs pressure-oilers? Would both trucks be four-speeds (I did not look at that when I saw them)? What rear gears is that 1/2-ton likely to have? Where is the serial number located on a '50???
Thanks in advance!
Patrick
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
Questions: What engine would both trucks likely have? *** 228 full pressure engine *** Aren't all of the AD GMCs pressure-oilers? *** YES*** Would both trucks be four-speeds (I did not look at that when I saw them)? *** NO *** THE 1/2 TON CAME WITH A 3 SPEED OR A 4 SPEED. What rear gears is that 1/2-ton likely to have? *** 4:11 *** Where is the serial number located on a '50??? *** DRIVERS SIDE PILLAR.
Thanks in advance!
Patrick
Cool, thanks!
engine size is stamped on pad behind dist.
Patrick,
Here is some information on terminology:
1947 to 1955 GMC trucks were called New Design GMC trucks
1947 to 1955 Chevrolet trucks were called Advance-Design Chevrolet trucks
OK, nice to know that --- I thought both were AD.
