0 members (),
70
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | I'm getting an engine ready for my 1937 half-ton (going with the original 216, etc.). I've got two carbs to chose from, a Carter W-1 that came with the truck and a YF model 964S that came on the 37 engine I plan to use.
What is the better carb to use?
What are the major differences between the W-1 and YF?
I've worked on Rochester carbs for my 53 Chevy sedan and 59 1-ton and am not familiar with the pros/cons of the Carters.
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I dunno about the YF, but I had good luck with the Carter W-1 on my 1-ton. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The W-1 would be original for your truck. I believe that the YF was a replacement carburetor. If your concerned about being correct you may want to check the numbers on the W-1 to see if its the correct '37 unit. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Carter produced 128 different models of the W-1 carburetor, many of them used by Chevrolet (1932-1949). The 1937 and newer are very good units.
The YF came later (1950), and was slightly more technilogically advanced.
The major difference as important to the enthusiast (thanks to ethanol), is the composition of the accelerator pumps. The W-1 pump is leather (totally impervious to ethanol). The YF uses a neopreme diaphragm, which holds up well in daily drivers, but tends to crack over time for vehicles which are not driven often. For a daily driver (or a vehicle for which the owner can acquire genuine gasoline) the YF remains an excellent choice.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | Thanks for the info. What number on the W-1 would indicate the year, etc.?
Also, the W-1 seems to be more complicated in makeup, with the spring/hinged choke plate and other moveable parts. Any special things to look out for when rebuilding?
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Don't loose any of the little hair-clip springs. You wouldn't believe how hard they are to find, even if you are working at the kitchen table! You can read through the pertinent pages here: http://old-carburetors.com/Chevy.htm | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Think you will have better luck finding a W-1 to fit your 216 then a YF. There are a lot of YF's out there. But me myself have ran across more W-1 for 216 then YF | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I like the W-1. The YF has a flimsy diaphram in it that you have to be real careful with when assembling. The W-1 is very reliable. We have one on my partners 36 fuel truck that had set for 30 years. The carb still works good. I said "we better go through the carb" & he said "what for". The only thing about the W-1 is that kits arn't avail. through the local part stores but specialty stores have them like Carbking. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I would go for the W1 I put one on my 52-216 and it had good gas milage ,good starting ,just a real dependable carb and it looks like it belongs on the engine.
Pete | | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | That's good info, but where is the model number stamped on the W-1? Not that it really matters, but just curious since the Carter info listed models and years.
What was the difference between economy and a standard W-1?
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
