3 members (Steelonsteel, Otto Skorzeny, 1 invisible), 60 guests, and 2 robots.
Topics128,054
Posts1,055,780
#807781 12/17/2011 11:11 PM
When adjusting the door striker plate, should I make any allowance for the rubber weather stripping that will go around the door? It is not on at the moment and I was wondering if I should adjust the striker so that the door closes flush with the surrounding surfaces of the body or if I should leave some space for the weather stripping.
1956 Chevy 3200
I have always adjusted without the door seal so the door is even with the cab sheet metal then install the seal when almost all done with the rest of the cab.
Mike
