Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (78buckshot), 176 guests, and 3 robots.
Topics128,274
Posts1,058,433
Members48,490
#807678 12/17/2011 4:33 PM
the generator on my 56 235 has a condenser (capacitor) on it. I assume this is for radio noise suppression or maybe it has another purpose? in any case the single wire that comes out of it has brittle insulation (in places it is cracked/missing) and i was wondering if this part (or equivalent) is available? thanks
not available from repro vendors, might check at someplace like Radio Shack if you can read the value on it - isn't necessary even if you have a working original radio
thanks Bill - figured that was the case. it has been painted over several times (it appears) so it is tough to see the value, manufacturer, etc.
