0 members (),
95
0
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | the generator on my 56 235 has a condenser (capacitor) on it. I assume this is for radio noise suppression or maybe it has another purpose? in any case the single wire that comes out of it has brittle insulation (in places it is cracked/missing) and i was wondering if this part (or equivalent) is available? thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | not available from repro vendors, might check at someplace like Radio Shack if you can read the value on it - isn't necessary even if you have a working original radio
Bill | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | thanks Bill - figured that was the case. it has been painted over several times (it appears) so it is tough to see the value, manufacturer, etc. | | |
