8 members (Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren),
83
Mod | | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Is there any reason why an oil pressure and water temp gauge would need a resistor to be converted to 12v? They are just mechanical gauges right? I don't see any power going to them. Am I right or wrong. Voltmeter-resistor or not?
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | you are right, no resistors needed for those. even the amp gauge will work without a resistor. Gas will need one. | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Thanks- I thought so. I find many times that this forum is soooo good that it's almost too easy just to ask the ? here. You normally get an answer right away. I have to stop myself sometimes and ask, do I really need to bother someone with this question!!! The info available from everyone definitely makes this "work" more enjoyable. I mean learning how to do all these different aspects of a rebuild is hard enough even with the answers!! Thanks again!!
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | You will need 12v bulbs for your gauges.
Good luck | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | 10-4 on the bulbs. Already got em in there. Gas gauge resistor done and working. 12v gen-rebuilt. Rebuilt 6v starter but most everyone says that'll be OK as long as I don't run it too much-heat it up. So really I should be done with the gauges. Only potential problem I can see is the headlight switch is tempermental. When turning left to right It flickers and has a hard time hiting just the right spot. Looks like that might be normal though 'cuzz of the way it's designed. That connection between the shaft and that spring looking part has gotta be ancient technology!!!! Its clean though and not corroded sooo- I guess it is what it is!!!!
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The instrument lights are flickering?
| | | | | Joined: Jul 2011 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 74 | I just read that you need a resestor in line for the gas gage. I have a 1948 chev panel and is 12v. There is one wire from the ignition and the wire from the gas tank going to the gage. Thanks for your help again. | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Yes u need a resistor in line for the gas guage if u are converting from 6v to 12v. My sending unit in the gAS tank was "blown" (wire on unit inside tank literally broke) probably due to running 12v w/out the resistor. The resistor will go between the ignition switch and guage. Do a search for correct resistor as it has been coverwed many times. Or I'm sure someone will chime in with right one. I'm just old and can't remember!!!!
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Yes lights flicker when i mess with headlight knob in a left or right direction. Sometimes have to do this for dash lights to work. Is sw. going bad?
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I had a problem one time with a flickering Headlight. It was due to a bad ground.
Your instrument lights ground when you snap them in the gauge housing, unless there is some fresh paint causing a bad ground I dont think that would be your problem.
I believe Denny Graham has rebuilt a headlight switch. Maybe He or someone else will chime in with some helpful troubleshooting tips
Good Luck | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | The rheostat on the switch that controls the brightness of the dash lights is most likely dirty or corroded and just needs a little cleaning up.
Get some contact cleaner from Radio Shack or any electronics store, spray a little on the wire-wound rheostat that is on the front of the headlight switch body (closest to the dash) then "wipe" the switch back and forth several times. Repeat as necessary. | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | It may very well be the ground. It seems that it- the light switch- grounds with just the round retaining nut that holds it in the dash. Just a little loose could cause that. Thanks
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Will also try that contact cleaner- never knew there was such a thing!!! Thanks
