4 members (Otto Skorzeny, Nick in Manitou, gswbbc, tclederman), 87 guests, and 2 robots.
Topics128,031
Posts1,055,436
Members48,422
#807437 12/16/2011 5:13 PM
Does anyone know how to check a heater motor to see if it works? First off I don't know if it is 6 or 12 volt. I am going to assume( I know, I know) it's 6 volt cuzz it's in my 52. It has one wire coming off the motor. Touching it to a 12v battery does nothing. And if it does work, are the resistors sold by LMC made for this application, going from 6 to 12 volt, worth it or should I just spring for a new 12v heater motor?
'52 3100 "once a Marine, always a Marine!!
assuming when you touch that single wire to the 12V [+] that you also have a wire from the motor case to the [-], no reaction and no spark says the motor is bad ... if you're changing to 12V you might as well find a 12V motor to fit
Yeah I grounded it. Nothing. Will just buy a new 12v motor since I am changing whats left to 12v. Thank u for the info.
