| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Does anyone know how to check a heater motor to see if it works? First off I don't know if it is 6 or 12 volt. I am going to assume( I know, I know) it's 6 volt cuzz it's in my 52. It has one wire coming off the motor. Touching it to a 12v battery does nothing. And if it does work, are the resistors sold by LMC made for this application, going from 6 to 12 volt, worth it or should I just spring for a new 12v heater motor?
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | assuming when you touch that single wire to the 12V [+] that you also have a wire from the motor case to the [-], no reaction and no spark says the motor is bad ... if you're changing to 12V you might as well find a 12V motor to fit
Bill | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Yeah I grounded it. Nothing. Will just buy a new 12v motor since I am changing whats left to 12v. Thank u for the info.
