| | | Forums66 Topics128,036 Posts1,055,448 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 74 | I have a 1948 chev panel one ton and I do not know what engine is in it. Just to the left of oil stick on a flat area there are numbers f523j and behind the top of the starter there is f218. Are any of these numbers helpful. Thanks 1948 chev panel
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | F523J F = Flint, MI plant 5 = May 23 = 23rd J = 3100-3200-3800 regular production 235 truck engine with mechanical lifters (originally used in a manual transmission truck) F218 - block date casting code F = June 21 = 21st 8 = 1958 Most likely the valve cover is attached with 4 machine screws on the side. Most likely, the water pump body is completely below the head. Here are locations of other casting codes | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | tim, do you just do this off the top of your head or do you have to look it up  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | tattooed on my legs | | |
