0 members (), 122 guests, and 3 robots.
Topics128,271
Posts1,058,314
Members48,485
#807258 12/16/2011 2:07 AM
I have a 1948 chev panel one ton and I do not know what engine is in it. Just to the left of oil stick on a flat area there are numbers f523j and behind the top of the starter there is f218. Are any of these numbers helpful. Thanks 1948 chev panel
first48 #807280 12/16/2011 3:04 AM
F523J
F = Flint, MI plant
5 = May
23 = 23rd
J = 3100-3200-3800 regular production 235 truck engine with mechanical lifters (originally used in a manual transmission truck)
F218 - block date casting code
F = June
21 = 21st
8 = 1958
Most likely the valve cover is attached with 4 machine screws on the side.
Most likely, the water pump body is completely below the head.
Here are locations of other casting codes
tclederman #807376 12/16/2011 2:24 PM
tim, do you just do this off the top of your head or do you have to look it up ohwell
51 ashton #807412 12/16/2011 4:15 PM
tattooed on my legs cool
