Hi, the above truck is my first ever old Chevy. It appears to be the WWII era version--painted grille, leather fill neck seal, steel ID plate on cowl, plastic or rubber covered inside door handles, etc. I'm currently working on the grille. It has 4 colors. Earliest appears to be blue then silver, gray and then white. What color was the grille when the truck was sold new? The truck appears to have been blue originally.
Also my VIN number on the ID plate has 9 BK 43 and then the serial number 74xx. I think I've seen the "9" decoded as manufactured at the Ohio plant, but what does the 43 mean? Thanks In Advance Don
