| | | Forums66 Topics128,026 Posts1,055,409 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | Im replacing some brake lines and brake cylinders on my truck. Awhile back i though i read something about being able to over extend and ruin the master cylinder? im afraid i might have done this because i pushed the break all the way to the floor at one point. How would i check to see if the brake cylinder is ruined or not? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Its doughtful you damaged it by overextension, but its a good idea to o-haul or replace it when you are doing brake work & pumping the master cyl. like that. You will push the pistons & cups into areas in the cyl. that have not been used for a long time & are full of crud & corrosion. The master cyl. will fail in a short time. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Good stuff George.
I purchased the tiny honing tool, found at the usual suspects in your area (FLAPS), commonly used when rebuilding master cylinders & wheel cylinders. If the bore is not corroded, to badly, the hone works great. Nice tool for minimal investment. | | |
