| | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 22 | There is weatherstrip on the door itself but none one the cab and I can see daylight I know about the windlace and the channel it fits in is there anything else . anybody have any upclose pictures of a fully weatherstripped door | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | If you can see daylight, then couple of things come to mind. Door isn't closed all the way shut or it needs new weatherstrips! Doors should have "two" latch positions, make sure the door is getting closed. | | | | | Joined: Nov 2011 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 22 | Thanks just got this truck and know little about it. Will check this out as neither door seems to shut well, | | | | | Joined: Feb 2000 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 41 | There should be weather stripping on both the door and the cab. You may be missing the cap weatherstrip. It slides into the channel on the inside of the cab. Replacement is available from many places. It can be pretty tough to slide a whole new strip in. I purchased one that I just couldn't make work. Then I purchased a good quality rubber one from Steele and it went in pretty nicely and looks and works great. | | |
